SPL: P3d415 vs CVR15
Bandieramonte
Hello;
Between the RF P3d415 and the CVR15, which one can produce more SPL on a ported box with each of their recommended enclosure meausures? (Assume that both subs are properly powered by an amp, up to their optimal wattage levels)
Specs from their respective official web pages:
P3d415:
Size 15"
Impedance 4-Ohm x 2
Power Handling 500 Watts RMS
1000 Watts Max
Voice Coil Diameter 2.5" 4-Layer
(6.35 cm)
Motor Size 102 oz. double stacked
Speaker Connector Dual 10 AWG compression
Fs (Hz) 22
Re (Ohms) 6.60
Le (mH) 6.0
Qms 6.50
Qes 0.660
Qts 0.599
Vas (Liters) 141
Sd (cm2) 790
SPL (1w/1m) 86 dB
Xmax (mm) 16.2
Woofer Displacement 0.107 cu. ft.
(3.03 Liters)
Cutout Diameter 13.875 in.
(35.24 cm)
Mounting Depth 7.625 in.
(19.37 cm)
CVR15:
Size (IN.,CM) 15, 38.1
Impedance (OHMS) 2 or 4 DVC
Max Rec Amplifier Power (WATTS PEAK/RMS)* 1000/500
Sensitivity (dB 1w/1m) 89.1
Frequency Response (Hz) 25-500
Mounting Depth (IN.,CM) 8 1/8, 20.6
Mounting Cutout (IN.,CM) 13 7/8, 35.2
Min Rec Sealed Box Volume (CU. FT., Liters) 1.8, 51
Max Rec Sealed Box Volume (CU. FT., Liters) 5.2, 147
Min Rec Vented Box Volume (CU. Ft., Liters)** 3, 85
Max Rec Vented Box Volume (CU. Ft., Liters)** 5, 142
do a search dude, the P3 and CVR have been compared plenty of times... after a little bit of searching you may even discover there are brands that exist that your local stereo shop doesn't carry that are better and cheaper //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
Yes spencer, the first thing I read on this forum is rule number 3:
3) SubX vs SubY
- Do a search. Seriously. At least 100 threads on every possible sub.
Yes, I did search all this forum and did not find a single thread comparing these subwoofers. I also searched on Google, to no avail.
If you're so sure there is a thread about this, you should have at least posted a link, and pour even a minimum amount of quality onto your post.
I congratulate you for having better access to more brands, and don't have the trade barriers we have. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Bandieramonte
Bandieramonte
Caracas, Venezuela
07BronzeFuz
