1. Product: audio-control EPIC160
2. Specs:
EPIC-160 SPECIFICATIONS
All specifications are measured at 14.4 VDC (standard automotive
voltage). As technology advances, AudioControl reserves
the right to continuously change our specifications, like our
weather, although we are working on it.
Maximum input level............................................. .............. 15 Vrms
Maximum output level .................................................. . 13.5 Vpeak
Frequency response ........................................10Hz-100kHz;+/-1dB
Total harmonic distortion .................................................. ... 0.003%
Signal to Noise ratio .................................................. .......... - 130dB
Balanced input noise rejection ................................................. 60dB
Microphone acoustical level................................... 70 dB to 160 dB
High SPL Warning .................................................. .............. 120 dB
Input Impedance .................................................. ............ 10 Kohms
Output Impedance......................................... ................... 160 Ohms
Power supply ................................................ High headroom PWM
Power draw .................................................. ......................... 300mA
Recommended fuse rating .................................................. .... 1 Amp
Size .................................................. ............ 6.75" W x 5" D x 1" H
Weight .................................................. ..................................... 2 lbs
Patent Number .................................................. ................4,698,842
built in 160db SPL mic and voltage monitor
3. Description/Condition: used 10/10 electrical 8/10 physical
4. Price: :$110 shipped.i may trade for?
2. Specs:
