SPL - How to connect 8 amps to one set of sub outputs on cd player?
davidtemple
Caraudio Guru
a friend of mine has 4 Soundstream amps ( XXX-6500D ) connected right now , but he wants to add 4 more how does the Big SPL guys do this? I think he was using Y cord to the amps.. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif I think you can strap 2 at a time
his last SPL car won alot in MECA but he was only using two JBL a3000's. So it was not a problem
thanks for all the advice.
there are 2 options (IMHO):
1. run one RCA back to the first amp, then go from out on one amp to in on the next (daisy chain)
2. run one rca into however many "y" splicers you'll need (might want a line driver to keep the signal voltage up)
davidtemple
Caraudio Guru
davidtemple
Louisville, KY
jvk5o1
