hey just wondering is it worth it? and does it actually put out the power if so how does it sound??? also would this be able to drop to .5?
Gorilla Series Class D Digital Monoblock Car Amplifier
RMS Power Rating:
4 ohms: 1700 watts x 1 chan.
2 ohms: 2500 watts x 1 chan.
1 ohm: 3200 watts x 1 chan.
Max power output: 5500 Watts
Regulated MOSFET PMW power supply
Bass Remote Details (Wired remote bass level control included)
All connections on the front side for easy installation
LED power indicators
Bass Boost (0-18 dB bass boost at 45 Hz)
Phase Shift (180 Degrees)
Mono channel operation
Bridged Synchronization (Strap amps together to double your power!)
Preamp RCA outputs
3-Way system protection circuitry (thermal, overload, and short protection)
Brilliant silver texture coat finish
Heavy duty die cast aluminum alloy heatsink for extreme heat dissipation
Silver-plated RCA level inputs
Silver-plated screw terminals
Variable low-pass filter (40-200 Hz, 12 dB/octave)
Subsonic Filter (12 dB at 20-50 Hz)
Frequency response: 15-150 Hz
Dimensions: 17"L x 8-1/4"W x 2-1/8"H
4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
RMS Power Rating:
Preamp RCA outputs
