question..... i also have a blazer. so your saying 3 inches from the hatch may increase the SPL? is thats for a Burp or Like Bassracing? cause i dont do burps. i do a bass race type of compThis is for spl, keeping the port with in 3" of the rear will normally increase the spl in blazer from what I have tested.
In order to check the tuning, we would need the following..I was thinking about stopping right where the cargo tie down hooks are,which is about 4to inches. Looks like ill end up doing about 3.75 for 2 12s, a single 8ex inch aero inside the box tuned to about 41. Buck, if you don't mind to would you double check what port length that would require overall with the flares? I think about 15.7 ish if I calculated correctly.
