Speakers only work at low volume
  • 2
klmclafferty
I'm at a loss here, I bought an old truck with the head unit missing, so I bought a new one and hooked it up. The sound that came out sounded okay at about 20% volume, past that it sounded shakey and distorted. I assumed the speakers were the issue, so I bought new speakers and had the same problem. Next I ran all new wires from the head unit (constant, ignition, ground, and speaker wires) still did it. So I figured there wasnt enough power, so I got an amp and everything sounds distorted at all volumes with the amp hooked up. Idk what else to try and I need a radio I can listen to. Im not looking for the best sound system ever, just something to sound as good as the factory.
I really need help getting this fixed, shops quote me around 500 to fix it and that is not happening.
Head unit: Pioneer DEH-S1010UB Single CD Receiver with USB
Speakers: Scosche HD6904SD - 6x9" 4-Way Car Speakers (Pair)
amp: BOSS Audio R1002 - Riot 200 Watt, 2 Channel, 2/4 Ohm Stable Class A/B, Full Range, Car Amplifier
amp kit: BOSS Audio KIT2 8 Gauge Amplifier Installation Wiring Kit
I suspect there is a factory amp that needs a low level signal and you are giving it a speaker level signal.  if so, feed the factory amp with the aftermarket head unit RCA outputs, or bypass the factory amp altogether (assuming speaker quantity and impedance make sense).
291
I would pull the HU and bench test it. Can be done with a 12v battery on a non-metal work bench easily enough.
16
145
455
klmclafferty
klmclafferty
keep_hope_alive
slater
    May 2, 2024
slater
    May 2, 2024
