Used for about 10 days testing it out. This amp has not seen any competitions!!
Need $800 + shipping out of it
Specs from ROE....
Output Power at 1% THD+N (manual):
1 x 2130W @ 4 ohm (13.5V)
1 x 2200W @ 4 ohm (14.4V)
1 x 2268W @ 4 ohm (16V)
1 x 3350W @ 2 ohm (13.5V)
1 x 3700W @ 2 ohm (14.4V)
1 x 3846W @ 2 ohm (16V)
1 x 4770W @ 1 ohm (13.5V)
1 x 5300W @ 1 ohm (14.4V)
1 x 5520W @ 1 ohm (16V)
The page lists (RMS, unknown voltage and THD): 5500W @ 4 ohm, 7500W @ 2 ohm, 10000W @ 1 ohm
S/N Ratio: >80 dB
Damping Factor: >350 @ 80Hz (+/-5Hz)
Operating Freq. (band-width): 15Hz ~ 150Hz
Dimensions: 26.85" x 11.42" x 2.56" (68.2cm x 29cm x 6.5cm)
Max. DC current: 545A DC (1 ohm, 13.5V, 1% THD+N)
Seems very similar to XXX-6500D but a closer inspection reveals some extra fets and cap
on the output stage section. Also more cables run from the input to the output stage (3 vs. 1).
Specs from ROE....
S/N Ratio: >80 dB
