cheefrawker
I don't know much about Rockford Fosgate but I've heard that Soundstream's stuff has started ******* due to the fact all their stuff is assembled in Korea. I jes don't know whether this is old school Soundstream or new SS. I've been looking for an Amp that runs 2000 watts @ 2 Ohms and both of these do that but I wanna know which one is better.
Soundstream Tarantula - Soundstream Tarantula 1 Ch 2000 Watt Amplifier
* NUMBER OF CHANNELS 1
* OUTPUT POWER (WATTS):
* RMS @ 4 Ohms 2000
* RMS @ 2 Ohms 2000
* T.H.D.:
* FREQUENCY RESPONSE (Hz): 20 - 500
* SIGNAL TO NOISE RATIO: >86dB
* CHANNEL SEPERATION: >60dB
* DAMPING FACTOR: >500
* INPUT SENSITIVITY: 300mV - 5.0V
* CROSOVER SLOPES: High-pass/Band-Pass 24dB
* CROSSOVER FREQUENCIES (HZ): Low-Pass 35 - 500
* HAWKINS BASS CONTROL (SUBSONIC POSITION): Variable High Pass (no boost) 13 - 30Hz
* HAWKINS BASS CONTROL: (On position)
* Variable Bass Boost 30 - 70Hz
* Variable Bass Boost 0 - 9dB
* DIMENSIONS (INCHES) : 19 x 14 x 5.5
Rockford Fosgate T30001BD - Rockford Fosgate 3000 Watt Mono Amplifier
1000 W x 1 @ 4 Ohms RMS
* 2000 W x 1 @ 2 Ohms RMS
* 3000 W x 1 @ 1 Ohms RMS
* Total power 3000 Watts
* Bridgeable:Master Sync, Power Sync (bd-sync2)
* Crossover:LP 32-250Hz 24dB per Octave, Subsonic Filter 28Hz
* Tone controls:Bass Control, 0 to 18 dB @ 35-70 Hz
* Signal input: Low level - , Quantity - 1, Type - RCA(pr)
* Line output: 1 RCA(pr)
* Phase control: 0/180 degrees
* Power input: Connector - Block, Wire gauge - 1/0 AWG
* Speaker output: Block
* Heatsink: Type -Cast, Cooling -Fan Cooled
* Remote control: Included, Type - Wired, Controls - Bass
* Class B/D
* Dimensions: 2.6 X 12.8 X 33 (inches)
I can find the SS for about $900 bucks and the Fosgate for $1400. please Tell me which one you think would be better for Crystal CMPX215. (I know I posted this before but last time i was asking whether 2000 watts or 2500 watts would be better). Much help is appreciated.
I'm also gonna throw this one in. I gotta friend who wants to use it to power his Solo X 12"
Visonik V4000XD
* Rms Power @ 14.4V DC: 1 x 2500W @ 4 Ohm, 1 x 3500W @ 2 Ohm
* Rms Power @ 17V DC: 1 x 3000W @ 4 Ohm, 1 x 4000W @ 2 Ohm
* Dimensions (H x W x L): 3.125" x 10.5" x 26"
* 12 - 17V DC Power Input
* 0.2 - 8V RCA Input Voltage
* Frequency Response 10 Hz - 350 Hz
* Short / Overload / Thermal Protection
* Bridgeable with second Class X Amplifier
* 24dB Variable Subsonic Filter
* 24dB Variable Low Pass Filter
* 0 - 18 dB Variable Bass Boost
* Remote Gain Control module
* RCA Line OutPut
* RMS @ 4 Ohms 2000
* RMS @ 2 Ohms 2000
* T.H.D.:
* Class B/D
Visonik V4000XD
* RCA Line OutPut
