fanaticalmoose
Which sub should i get, i can get the ED 13Ov for around $300 shipped for two of them. There 600 wrms and D2's....
The Soundstream VGW-12 is also 600 wrms and 1200 wpeak and i get two for $220 shipped.
here is the info for the Sound stream..
Specifications:
• MAX POWER (WATTS): 1200
• RMS POWER (WATTS) : 600
• VOICE COIL DIAMETERS (INCHES) : 2.5
• MAGNET WEIGHT (Oz.) : 120
• FREQ. RESPONSE (Hz) : 22 - 1.2k
• Fs (Hz) : 29.0
• Qes: 0.474
• Qms: 8.032
• Qts: 0.448
• Vas (Ft3) : 1.81/48.49 liters
• Xmax (INCHES) 0.649
• SPL (dB) : 87
• HOLE SIZE (INCHES) : 11.25
• WOOFER DEPTH (INCHES) : 5.9
• RECOMMENDED ENCLOSURE (Ft3) : 0.6/0.8
• RECOMMENDED ENCLOSURE TYPE : Sealed
info for the ED 13Ov..
Spec 13Ov.2 Subwoofer
Qts .28
Qms 3.3
Qes .3
Re 8.3
Vas (Liter) 176
Sd (cm^2) 545
Fs (Hz) 21
Bl 21.7
MMd 127.00
MMs 134.00
Xmax 18.3
13Ov.2 Subwoofer Dimensions / Physical Information
Voice Coil 2.5
Spider Single 7
Tinsels Woven
Mounting Depth 6.75
Mounting Diameter 11.00
Displacement 0.09cF
they are going to be powered by a Rockford Fosgate X7.A at 2 ohms or 4 ohms (not sure yet)... the amp is a 1500 watt mono... All gooes in a 2003 Honda Accord 4dr... Thanks for the help guys...
Specifications:
• Fs (Hz) : 29.0
• Qes: 0.474
• Qms: 8.032
• Qts: 0.448
• SPL (dB) : 87
Qts .28
Qms 3.3
Qes .3
Re 8.3
Vas (Liter) 176
Sd (cm^2) 545
Fs (Hz) 21
Bl 21.7
MMd 127.00
MMs 134.00
Xmax 18.3
Voice Coil 2.5
Spider Single 7
Tinsels Woven
Mounting Depth 6.75
Displacement 0.09cF
