soundstream t4
they are all good subs but I am partial to the brutuses personally, best bang for the back IMO but i am partial to hifonics over almost all of the main stream brands. there are alot of high end products that are better but of the 3 you listed I have used em all and definately prefer the Brutus
well i am running a hifonics bx2005d at 1 ohms close to 2,000 watts so idk if the hifonics brutus subs can handle that when there max power ratein is 600rms and 1,200watts max
if ur amp is putting out 2000 watts then it will tear apart the kicker and lanzar. the brutus might be ok but u need to be cautious when turning up the volume. I ran one of my brutus on my amp (1300rms) for a day and it seemed ok but i had the gain down and didnt blast it full volume.
check out the re-se or sx. they should be able to handle the power. i have also seen the audioque sdc2.5s running off 2000 watts for a pair
I THINK THE LANZARS MIGHT HANDLE THE POWER THEY ARE RATED 1,100 WATTS RMS AND 2,200 WATTS MAX
can two 12'' soundstreams t4 subwoofers handle a hifonics bxi2005d amp at 1 ohms for everyday playing or would that amp be over powering the subs
in all honesty they should be able to handle it just fine. ive known a few peeps that have ran the T4s with quite a bit more then RMS power to them. If your using a pair on a 2005, it will be ok. like previous posts, just be careful.
Good subs.
texicanz
texicanz
moline,il
hazardous0388
