Hey all, im new here but have couple quick questions. i just purchased two new soundstream splx12-4 quad vc 1.2ohm a piece. im running them bridged on my oldshcool rubicon 1002 at 1ohm bridged 10awg to each coil. .5ohms a sub all in parallel then to the amp from the box in series to wire 1ohm. i dont even get these things turned up 1/2 way up where i ran the amp b4 and its clipping off the amp soon as it goes to hit. if anyone a oldschool soundstream fan these amps are amazing.
i just upgraded from 2 oldschool soundstream spl12s that i ran in stereo 500rms a piece at 2ohms a channel and ran just fine if played 144sdb+ for 15year old subs. to me this amp should be doing the 1ohm bridged because ive have had it .75 a channel stereo stable np. do you think something could be wrong with one of the subs? or do you think im lacking power and i know most people say ya you are u need another battery. but i ran 3 spl12s 2.6ohms and 2spl10s 2ohms a channel so using as a tri 3channel amp np. im running 0awg from the battery 250amp fuse then 4awg to my amp. does having total 8VC causing the amp to see to much of a load briged at once? and i know the amp is deff plently for now because anyone knows how the old amps are their not rated by watts its amperage cause below 2ohms then stopped giving it a rating and they produce crazy power below that.
