Soundstream Reference 2.640 2 channel. Over 600rms. excellent sound $160 shipped
gentlejax
Item(s) for Sale:new model Ref 2.640
Specs:Soundstream Reference Series 2-Channel Class A/B Car Amplifier
RMS Power Rating:
4 ohms: 190 watts x 2 chan.
2 ohms: 285 watts x 2 chan.
Bridged, 4 ohms: 570 watts x 1 chan.
MOSFET power supply
RUBI (Rapid-Use Branched Impulse) proprietary power supply technology
STACT (Stabilized Apex Current Technology) reduces power supply stress by 50%
Hawkins Bass Control (0-10 dB bass boost at 15-4000 Hz)
Trident amplifier power topology
2 channel operation
Vortex induction fan thermor management
Ultra-low ESR capacitors ensure rapid power delivery for dynamic peaks
Harmonic Bass Alignment produces tighter, clean bass
Rail stabilization protection circuitry
Balanced line inputs for highest noise rejection
Triple Darlington output circuitry
BIP (Bias Input Protection)
Heavy duty aluminum alloy heatsink for extreme heat dissipation
Gold-plated RCA level inputs
Gold-plated screw terminals
Tri-mode operation
Variable high-pass filter (15-4000 Hz, 12 dB/octave)
Variable low-pass filter (50-4000 Hz, 12 dB/octave)
Bass Boost (30-80 Hz, 12 dB/octave)
Frequency response: 10-50,000 Hz
THD (Total Harmonic Distortion): 0.02%
Signal-to-noise ratio: 115dB
Input Sensitivity: 0.2-9 volts
Damping factor: >200
Dimensions: 15-15/16"L x 9-7/8"W x 2-1/8"H
Item(s) Description/Condition:used but in great shape. few nicks here and there but looks very nice. has great controls and specs.
Price:$160
hooked it up today.
very clear and dynamic. I didnt change anything and am listening to the same stuff I always do and it sounds very detailed.
this is as good as the original as far as sound. will it last 15yrs ? dont know. does it sound very good? yes. it does
anyone who says the new is not as good as the old hasnt heard the new. I have , I have had the old many times. this is every bit as good and clean as the old. much clearer than the Boston Acoustic I had before in the same install. this is crystal clear.
very dynamic and the left /right channel seperation is great. I am hearing stuff I havnt heard quite the same before. detailed.
gentlejax
gentlejax
Bossier City, La.
gentlejax
