*Ace*
I live in Las Vegas and the summer heat is just too brutal for this amp. The amp is sealed off in a trunk of a 2011 Civic and when temps are 100+ the amp will go into protect after about 30-45 minutes of play. If the temp is below that it plays fine without ever going into protect, however during the summer here just about every day is above 100. If you live in an area where the temps don't get that high then the amp will run just fine for you. I just don't feel like going through the hassle of adding a fan to cool the amp down.
I'm looking for a Elemental Designs Nine.2x or an amp very similar too it that runs very cool. I had this amp before and even though it would get warm during the summers here, it never went into protection on me, so I would like to have that amp again.
The new Soundstream Ref are suppose to sound just like the old ones. The amp sounds really good with my Image Dynamics CXS62 components, and the damping factor and THD are one of the reasons I got it to go with my components. Here are the specs for the Soundstream:
SPECIFICATIONS REF2.640
Channels 2
RMS Power @ 4Ω, 14.4V 2 x 190
RMS Power @ 2Ω, 14.4V 2 x 320
RMS Power @ 4Ω Bridged, 14.4V 1 x 640
Total Harmonic Distortion (4Ω power) 0.02%
Frequency Response 15-50kHz
Signal-to-Noise Ratio (4Ω power) 102dB
Damping Factor (100Hz, 4Ω) >1500
Dimensions: 2.25"h x 9.875" 16"
Ch. 1&2 HPF/Hawkins/Subsonic 15-210Hz or 260-4kHz
Channels 1&2 LPF (12dB Slope) 50-250Hz or 820-4.7kHz
External Fuse Required 80 A
Channels 2
