Sold soundstream pca 1500d
Jep772
soundstream pca 1500d for sale. ive had it in maybe 5 months, bought from an authorized dealer no refurb BS.. 100% problem free, never gets hot only thing wrong is some dust. have original box, ppr work, wire for strapping, sticker and bass knob. again i havent had any problems with this amp at all i just need to upgrade cause this DD is laughing @ 1500w
300.00 shipped. i'm paypal verified and have a few refs.
i can get more pics if needed
nice amp, i have its bigger brother the 2000d. i blew it and am tryin to fix it.
definately solid amps, they really dont get hot at all even after constant wangin on it in confined areas. i would assume the 1500ds are the same as the 2000ds..and my team has been runnin the 2000d's down to .35 ohm load stable for hours on end with no problems
definatley solid amps
good stuff, thanks for the bump!
it stays cool for sure, i drove all the way to ft. lauderdale (2 hours) bangin as hard as i could and it stayed cool, the sub got a lil warm though.
Monoblock Picasso Series Amplifier
Peak Power Output: 3000 watts approx.
RMS Power Ratings:
800 Watts x 1 Channel @ 4 Ohms
1100 Watts x 1 Channel @ 2 Ohms
1500 Watts x 1 Channel @ 1 Ohm
Bridged RMS Power: Not Bridgeable
Min. Impedance Unbridged: 1 ohm
Min. Impedance Bridged: Not Bridgeable
THD @ Rated RMS Power: 0.5%
Speaker Level Inputs: No
Amp Preamp Outputs: 1 Pair
Built-in Crossover: LP (50 - 150 Hz), Subsonic (15 - 40 Hz)
Bass Boost: 0 - 18 dB
Signal-to-Noise Ratio: 80 dB
Fan Cooled: No
Fuse Rating: N/A
TST (Twin Stack Technology): Allows 2 Amps to Drive One Voice Coil!
High Quality FR-4 Circuit Board
Class D Circuitry
Continuously Variable Low-Pass Crossover: 50 - 150 Hz (24 dB/Oct.)
Continuously Variable Subsonic Filter: 15 - 40 Hz (24 dB/Oct.)
Variable Subwoofer Equalizer: 0 - 18 dB
Phase Control: 0° / 180°
Frequency Response: 5 - 250 Hz
Adjustable Input Sensitivity: 0.5 - 4V
Damping Factor: >200
Fully Regulated MOSFET Power Supply
PWM Circuitry
Platinum Power and Ground Connectors
Accepts up to 16VDC Power Input
Wire Bass Remote Included
Dimensions: 15" L x 9-1/2" W x 2-1/2" H
OCS wants 499.00 pick this up for 3 !!!
Jep772
Jep772
Indianapolis, IN.
scutzi128
