Soundstream DTR 1.1700D
Spooney
7/10 physically and 10/10 functionally. Original mounting feet were broken(as are most any of them in this series of amps) so I made a new set out of some angle aluminum. All the terminal screws are new as well. For anyone not familiar with these amps they are made to be mounted vertically to save floor space. From everything I read and hear about these they do rated. Good sounding amps with clean power.
Specs as follows (copied from sonic electronix)
Soundstream D-Tower Series Monoblock Class D Car Amplifier
RMS Power Rating:
2 ohms: 1100 watts x 1 chan.
1 ohm: 1700 watts x 1 chan.
Full MOSFET Power Supply
The worlds first vertical automotive stereo amplifier
Double side PCB and SMD components
LED power (green) and protect (red) indicators
Monoblock operation
Gloss black finish w/ brushed accents
Dash mounted remote gain control
3-Way System Protection circuitry (thermal, short, impedance)
Heavy duty aluminum alloy heatsink for extreme heat dissipation
Nickel-plated RCA level inputs
Nickel-plated screw terminals
Variable high-pass filter (10-50 Hz)
Variable low-pass filter (40-220 Hz)
Subsonic Filter (10-50 Hz)
Bass boost frequency: 30-90 Hz
Bass boost level: 0-12 dB
Signal-to-noise ratio: >85 dB
THD (Total Harmonic Distortion): 0.5%
Damping factor: >200
Frequency response: 10-220 Hz
Dimensions: 14-5/8"L x 3-5/16"W x 7-1/2"H
Looking for 165 shipped in the lower 48 states.
Included in price. Most likely fedex ground
Spooney
Spooney
Charlotte,MI,USA
infamous_e46
