* 2x soundstream xxx-6500
Specs:
XXX-6500D
Channels 1 ch. Class D
RMS Power @ 2 Ohm, 14.4V 3,300
RMS Power @ 1 Ohm, 14.4V 5,300
RMS Power @ 1 Ohm, 16V 6,500
Total Harmonic Distortion 5.00%
Frequency Response 15-150Hz
Signal-to-Noise Ratio 80dB
Damping Factor 350
Signal Voltage 500mV-10V
Potential Current Draw 460A
Dimensions: 2.625"h x 11.375"w x 25.75"L
Low Pass Filter 18dB, 50-150Hz
Bass Boost 0-18dB, 45Hz
Subsonic Filter 18dB, 15-40Hz 18dB, 15-40Hz
Phase Control 0-180º
HIGH QUALITY SCREW DOWN TERMINALS
RCA OUTPUTS FOR EASY MULTI AMP SYSTEM EXPANSION
0 GAUGE POWER AND GROUND TERMINALS
Stylish New Exterior Finish!
* Gunmetal finish w/ brushed accents
* Non-regulated mosfet pwm power supply
* Three-way protection circuitry (thermal, short,
* impedance)
* Twin stack technology TM(strap amps together
* for double power)
* Delayed on/off circuit
* Variable low pass crossovers
* Variable bass boost
* Variable subsonic filter
* 180 O phase control
* Pre-amp outputs
* Dash mount remote gain control
* Direct wire 0 ga. Power, 4 ga. Speaker terminals
Description/Condition:
used but 8.5 out of 10 for normal scratches
still in my car, and did a 155.1 db 2 weeks ago
Price: :
$700 shipped each
$1300 shipped for the pair
sorry no trades
* 2x 8" flaired aero ports
Specs:
21" long flaired ports made by amartin_72
a total of 6 peices make these 2 flairs, so 1 flair is 1 of each peice
(2) 12" long pieces
(2) 5" long inner flairs
(2) 6" long outer flairs
only used 1, but the paint didnt stick well
Price: :
$88 shipped for both
$48 shipped each
* SPL Cell C115 group 31 drycell battery
Spec:
Height: 8.125" w/o terminals - 9" w/ terminals
Width: 13"
Depth: 6.625"
Weight: 71 lbs.
115 AH
equal if not better than kinetics, sits at 13v
aprox 2 years old
sits on float charge in my garage
Price: :
$170 shipped O.B.O.
*4 coils, all 4 layer flat wound used
2 2-layer round wound brand new
3 dustcaps new and used
1 15" cone and surround
Specs:
from left to right
was a MT D1, 3" ID 3.375" OD 2" ww 4.6" former
D1, 3" ID 3.25" OD 2.25" ww 3.625" former
D1, 3" ID 3.25" OD 2.25" ww 4.125" former
D1.5, 3" ID 3.1875" OD 2.25" ww 4.125" former
D0.6, 3" ID 3.25" OD 2.25" WW 4.125" former
3 dust caps 5 1/4"
slightly used and been in acetone to get glue off
2 used dustcaps, 1 new
15" cone, has a tear becuase some thing got stuck on it, but its just the top there and should be able to glue back down
Price: :
4 used coils - $20 each
2 new coils - $40 each
3 dustcaps - $10 each
15" cone - $15
+ shipping O.B.O.
will do combo deals
trades - I need skinnier coils and 8" spiders
Specs:
XXX-6500D
Damping Factor 350
* impedance)
* for double power)
* Pre-amp outputs
Price: :
$700 shipped each
sorry no trades
Specs:
(2) 12" long pieces
Price: :
$48 shipped each
Spec:
Width: 13"
Depth: 6.625"
Weight: 71 lbs.
115 AH
aprox 2 years old
Price: :
$170 shipped O.B.O.
Specs:
from left to right
3 dust caps 5 1/4"
Price: :
15" cone - $15
+ shipping O.B.O.
will do combo deals
