Sold Soundigital SD8K with new heatsink lnib
blazron22z
1. Product:
Soundigital 8k new heat sink
2. Specs:
Features
Frequency Range - 10Hz - 15kHz
Damping Factor - 200 @ 1 Ohm; 400 @ 2 Ohms
THD - Less than 1% at rated power
Input Sensitivity - 0.5 - 4.0 volts
Safe operation from 8 volts to 18 volts DC
Full bridge output topology
Adjustable subsonic filter (20Hz-50Hz) and low-pass filter (80Hz-15kHz)
Safety protection circuitry for low voltage, short circuit, high temperature, clipping and battery discharge
Soft-start and soft-shutdown operation
PWM Power Supply
High current nickel plated connectors
ESM - Energy Saving Mode
Power Output - 8,000 watts at 12.6v
Impedance Drive Options: Stable to 1 Ohm
Dimensions - 44cm x 27.7cm x 7.3cm (17.3" x 10.9" x 2.9")
Weight - 11kg (24.2lbs)
3. Description/Condition:
like brand new bought it brand new about a month ago and have only played with it for about one hour tops
4. Price: :
1250 shipped
5. Pictures:
dang on the no trades. Got a ? tho would you be willing to do a drop in test? If i like the results i'll buy //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif.
Come threw and we will throw it in there
blazron22z
blazron22z
lexington nc
blazron22z
