1. Product:
SounDigital SD400 (x2)
2. Specs:
Impedance Drive Options: Stable to 1 Ohm
Dimensions - 21cm x 29cm x 5.7cm (8.25" x 11.4" x 2.25")
Weight - 1kg (2.2lbs)
3. Description/Condition:
Brand New in the box
4. Price:
$350 shipped for both
They go for $399 each (SD-400.1D [sD400] - $399.00 : Mach 5 Audio)
5. Pictures:
Sample Video (Not me but the same model amps)
2. Specs:
- Frequency Range - 10Hz - 20kHz
- Damping Factor - 200 @ 2 Ohms
- THD - Less than 1% at rated power
- Input Sensitivity - 0.5 - 4.0 volts
- Safe operation from 8 volts to 18 volts DC
- Full bridge output topology
- Adjustable subsonic filter (10Hz-80Hz) and low-pass filter (80Hz-15kHz)
- Safety protection circuitry for low voltage, short circuit, high temperature, clipping and battery discharge
- Soft-start and soft-shutdown operation
- PWM Power Supply
- High current nickel plated connectors
- ESM - Energy Saving Mode
4. Price:
5. Pictures:
