Some Opinion from u all
i suggest getting different types of screws ( flat head, philips head, and allen heads ) you should try to mix it up so if someone wanted to steal them, they would have to bring like a huge bag full of different screw drivers. and what i did also to this was take out my carpent, put down the subs and amp, then screwed it directly to the ground and then layed the carpet back over it which made it a little harder to get to the bolts.
not only but also
use bolts through the bottom of the box before you screw in the sub, and put 2 nuts on the other side, then get a friend to hold the bolt head while you lock the nuts against each other. if any one wants your sub, the nuts and bolts will turn but not release, and if they figure out what youve done, they will still need arms like an orangatang to undo them
doug in new zealand
Martin
Martin
NY
ss3079
vegang
vegang
