Some General Physics questions i need help with..
Bumpin03
James Madison University
alright since car audio has a lot to do with physics i figured thered be some physics know-it-alls in here. im too lazy to look all these up on the internet or go through the text book. so heres the question....What is the purpose of these devices in terms of energry changes?
electric heater
electric motor
generator
alternator //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
transformer
light bulb
What is the difference between DC and AC current?
Thanks guys.
The generator changes the engine's fuel power (the pistons firing) into power. It runs a metal rod (or wire cluster, not sure) inside a cylindric magnetic coil, generating electrical current, to be used in powering all the car's accessories.
As for the others, I probably couldn't give you as good of a definition.
electric heater-changes electrical engery to heat via heating coils
electric motor-turns electrical energy into motion
generator-opposite of a motor..or rather a motor run backwards, turns motion into electrical energy
alternator -similar to a generator-takes motion from the motor and turns it into electrical current
transformer
light bulb-Electrical energy into light energy via a filament that heats/lights up
alternating current in us standards turns on and off 60 times a second
direct curren never turns off
Thats why your printer has a giant box where it plugs in because basically there is a cap in tere that hold a charge down to 12 volts so its always on and doesnt fluctuate as most electronics do
BTW lightbulbs are fillaments inside a vacumn that due to electric resistance heat up to tempeatures around 600degrees...and it makes the metal glow through all the visible light spectrum making the best white light it can.
A heating coil works in a similar way but is very closely regulated to turn off and only allow a certain level of power to reach the coil itself...basically they will burn hotter and hotter till they either melt or start a nice house fire.
Alternator was explained well enough, as well as the generator
Bumpin03
Bumpin03
Virginia
B&R Innovations
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
