Some clarification....
Frankensuby
I'm in Ur F0rumZ
929
PA
Just need to make sure I'm thinking right.
If an amp says that it's THD is .02% at 90 RMS, if I run the amp at 70 RMS, there is even less distortion? I know running it above it's ratings at sine wave increases distortion, but does less reduce it?
Depends on how its rated. Manufacturers are SUPPOSED to rate the distortion at their rated power output, but some companies will rate distortion way below their rated output just to get a better number.
Unless you drive the amp harder than where that distortion measurement was taken, it won't distort worse that that, no.
The distortion rating of an amp, in my experience is fairly flat. Looking at my arc's birthsheet it shows the distortion actually dropping as power is increased, but it's minimal. It's goes from .05 to .02 over a 500 watt range. Really it doesn't matter, all the variations on the graph are inaudible. Anyway,, once it hits 500 watts it shoots almost straight up. The next 50 watts are where it hits it's maximum allowed thd, 1% Like I said though, you won't hear it.
Random thoughts;
* Don't rely 100% on amplifier published specs to form conclusions.
* Distortion numbers will change based on frequency tested.
I have the 'binks'proamp shootout at those amps are tested at 1% THD+N
with 20hz, 1khz, 20khz tests. Each amp will reach 1% distortion at different power levels
at those different tested frequencies. 1% THD is considered the upper range of
inaudibility, but some folks can't even hear as high as 3% THD.
What is interesting is many of those amps output less power at the lower
frequency when it hits 1% THD+N. So, the 20hz score is lower power than
the 1khz score and less power than the 20khz score. Some amps are weird, they
output much less power at 20khz than the other frequencies so their topology
is suffering at high frequency playback.
Here's a very high end amp;
rated: 2200w/ch @ 4 ohms 20hz - 20khz
Tested;
20hz power = 1327 watts
1khz power = 2310 watts
20khz power = 648 watts
This amp really fails at 20hz and 20khz, outputting much less power
than rated at 1% THD.
Here's another very high end amp;
rated: 3200w/ch @ 4 ohms 20hz - 20khz
Tested;
20hz power = 3152 watts
1khz power = 3293 watts
20khz power = 4804 watts
This amplifer is much closer to published spec and it exceeded spec at 20khz testing.
Bottom line, any amplifier is subject to this even if it's a car amp, home amp,
pro amp, what they do in real life can be much different than ratings.
The last variable is the input power you give the amp. Those number can be different if
the supply voltage sags below nominal.
I don't know how valid birthsheets are either, will a manufacturer *really*
show you a bad birthsheet? lol ...
Random thoughts;
Tested;
Tested;
Thats some good Information, I Printed this out just to keep in my file.
These values change when you wire them in Series. I seen them jump all over the Scope when you add Two or more on a channel.
Hmm, well that blows in a way haha. Thta means whatever amp i get, I'd have to run a similar test to see what is going on?
Atleast I know better now.
Frankensuby
I'm in Ur F0rumZ
Frankensuby
PA
thylantyr
