fwb_1234
I recently set my gains using the official gain setting tutorial, and I set it to the RMS of my amp and subs (same - 400W). I realized that I could have set them to whatever the heck I wanted.
When I first got started, I was told my amp would not actually produce the wattage stated, but I could have set them to whatever I wanted to anyway.
I understand that at one point, my amp will start sending a distorted/clipped signal to my subs, which I can check with test tones, or, better yet, an O-scope. Another tutorial I read told me how to set gains by ear, by listening to tones and turning up the gain until the signal distorted, which makes much more sense, because you could adjust it to the exact point at which it started to distort, not the stated wattage proved by the manufacturer.
Does this mean that anyone with an O-scope (or good ears) can perform benchmark tests? If not, why?
Who creates the ratings that are incorrect (in cases where an amp is under/over rated)? Why are they off?
I'm just really confused how some amps are under/over rated, or even rated at all. Subs I understand; it's based upon how much heat they can handle before they burn up. It's amps that make me //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif ...
