Sold SI Mag v4, Arc Audio mini amp, Digital Designs mini amp, misc wiring etc.
pepsican
I just sold my Subaru Impreza and gutted all of the electronics out of it. I was going mainly for a stealthy install that added minimum weight. This car was not my daily driver. I have two amps from the install:
DD SS1 - It's small. Really small. Rated at 600x1 at 1ohm, but has been tested to do 1000k+. It drove my SI Mag V4 without any problems with juice to spare:
I also have a arc audio 125.2. It's even smaller. 65 x 2 @4ohm 125 x 2 @2ohm & 250 x 1 @4ohm mono:
Both amps are in very good - excellent condition. I can't say enough good things about them. I was able to mount both of these inside a small glove box. Awesome. $200 shipped per amp.
I also have a SI Mag v4. You can go here for the specs:
Stereo Integrity | SI Mag V4
Bought new for the suby. Great sub with a small mounting depth and minimal weight. Great SQ, decent SPL. $175 shipped:
MISC wiring - I have maybe 12 ft of 1/0 gauge, lots of 4 gauge, a 4 way RCA set, distro blocks, fuses, etc. Basically everything I used to wire the two amps and speakers. I will go through everything and see what I have later if someone is interested. Would much rather this be a package deal.
I also have a 12" enclosure from audio integrations made for an 02-07 wrx/2.5i impreza. It's in good condition, but I had to glue the trim ring to the cut out so my SI mag would fit. Besides that, it is in great shape, just needs to be vacuumed. $250 shipped:
Only trades I'm looking for would be a double din receiver w/nav or a nice portable navigation unit.
BTW, I would like to do unspeakable things to the lady in your siggy //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Thanks for the bump. Unfortunately that girl and I parted ways years ago, but hey, she might be single!
I went over the wire. All of the power wire is stinger custom pro.
1/0 gauge black - ~13 feet and ~1.5 feet
1/0 gauge red - ~ 3 ft
4 gauge red - 2 sections, ~4 ft
4 gauge black - 2 sections, ~3 ft
I chose black for the main power wire because it looked less out of place in the engine compartment. Not a big deal since I split the 1/0 and made the switch from black to red for the power wire. This might confuse some people, so I figured I would mention it. The fuse holder is tsunami ANL style. The RCAs are 4 channel stinger, and I have two 1/0 to 4gauge distro blocks. On top of that I have ~40 feet of stinger 12 gauge speaker wire.
I will be trying to sell this as a set first and foremost. This should easily cover a 2 amp system in most cars. It obviously wouldn't work for a larger SUV. $85 shipped takes it all.
I'm pretty much done with car audio, not looking for trades besides what I have listed (double din receiver w/nav or a nice portable navigation unit). Wish I could help.
pepsican
pepsican
iowa
winkychevelle
