Sold Several HEAVY duty Battery cables for sale; $25 each shipped.
Frankensuby
I'm in Ur F0rumZ
PA
I have several leftover NOS (New-old stock) battery cables that may be of some use for you audio guys. All of these cables are factory battery cables for Mack Truck battery stacks; some 1/0 gauge, 2/0 gauge, and even a single run of 3/0 gauge cables.
These cables have NEVER been used but are a tad dusty/yellowed (outer clear casing where applicable; black lining underneath is good though) from sitting in a warehouse for quite some time. These cables have either post type connectors or twist down connectors. These cables are going from roughly $40 to $80 online but they are of no use to me so I want them gone. I'll sell them for $25 a pop shipped. I'm figuring 20 dollars for the cable, 5 dollars for the shipping. If shipping is less I will refund the difference, if more I'll just bite the bullet. EDIT: Forgot to add; I take Paypal and PM me if interested in any of the cables.
Pics below:
Cable Type 1 - 3/0 gauge (crazy thick) Length from batter post (inner hole) to post = 30". Only one available - $25 Below:
Cable Type 2 - 2/0 gauge thickness. Length from battery post to splitter post = 56". One side has splitter for stacked batteries to one post. 5 Available - $25 each. Below:
Cable Type 3 - 2/0 Thickness 2/0. Length from inner post to inner post = 30" and outter post to outer post is 46". Made specifically for side by side battery stacking (think sort of 2 AA batteries side by side in your remote). 3 available - $25 each. Below:
Cable Type 4 - 1/0 Thickness. Distance between connectors (middle hole) = 48" These are just runs made for going between battery stack connections and the starter motor. Yes, 1/0 is necessary to turn these hunking motors! 5 available $25 each. Below:
Cable Type 5 - 2/0 thickness. This is a modified stack cable, huge run or 2/0. Probably made to run under the cab and connect the two stacks (trucks run 2-4 batteries on each side of the cab, so up to 8 batteries!) together. Distance between inner posts is a whopping 90" so you can probably split the wire up for your own use. - $25 only one available. Below:
Frankensuby
I'm in Ur F0rumZ
Frankensuby
PA
Frankensuby
