Technically, if you have the sub's full specs, it's not hard to calculate the TRUE sensitivity of the subwoofer regardless of the manufacturer's "stated" figure using the formula;It's a bunk term.
It means if you put a woofer on an infinite baffle, put a mic 1 meter directly in front of the cone, and apply exactly 1 watt at 1khz, you will produce XX dB of output.
The problems with sensitivity are as follows:
1) There is a lack of set standards. MFG's can easily cheat the system to make a driver look like it's more efficient than it really is. As an example, different SPL meters can vary by up to 10dB. Pick the right meter, and your 88dB driver becomes a 93dB driver.
SPL=112+10*LOG(9.64*10^(-10)*Fs^3*Vas/Qes)
Where Vas is in Litres
That said.....Sensitivity is pretty meaningless for the most part with regard to subs. About the only thing I use it for is a very brief reference to the subwoofers potential box size and low frequency output based on Hoffman's Law. Small box, sensitivity, low frequency extension. You can only have two of the three. So if a sub has a high sensitivity, it's a guarantee you are going to have to give up one of the two remaining.
Beyond that...it's of little use.
I see someone has been into the Adire Tech Papers. =) I totally forgot all about that until you mentioned it.Technically, if you have the sub's full specs, it's not hard to calculate the TRUE sensitivity of the subwoofer regardless of the manufacturer's "stated" figure using the formula;
I actually read about it in the LSDC.I see someone has been into the Adire Tech Papers. =) I totally forgot all about that until you mentioned it.
