ascitiesburn69
Ok I've been working on a model in sketchup for a little while and i think i got it right but someone wanna check my port length etc? Heres the pic:
. I want it to be tuned to 38hz and i'm 99% sure the port length is a little small. 5.3" wide port. and port length is 19.2"ish. Front is double baffled. Box is 5.84cuft net before any displacements and the port plus the wood used to make the port takes up .94 leaving me with 4.9cuft. I am using 2x sdc2.5's which displace .1 each, leaving me at 4.7cuft net after all displacements. Which, in my calculations makes me need a ~21" port length? Is this correct?
Ive also uploaded the skp file so you can have a look around the entire thing if you wish. http://www.mediafire.com/?u2wi4edxzml
Thanks alot guys.
. I want it to be tuned to 38hz and i'm 99% sure the port length is a little small. 5.3" wide port. and port length is 19.2"ish. Front is double baffled. Box is 5.84cuft net before any displacements and the port plus the wood used to make the port takes up .94 leaving me with 4.9cuft. I am using 2x sdc2.5's which displace .1 each, leaving me at 4.7cuft net after all displacements. Which, in my calculations makes me need a ~21" port length? Is this correct?Ive also uploaded the skp file so you can have a look around the entire thing if you wish. http://www.mediafire.com/?u2wi4edxzml
Thanks alot guys.
