Samsung scdc353.
2.5" lcd, records on mini dv tapes, also has a memory stick slot for the digital camera. Its a camcorder and a digital camera. Has maybe 10 minutes of use on it, if that. All of the original stickers are even on it still. It has all sorts of settings to adjust video/photo quality. Nice camcorder.
# Multi OSD Language
You can select the desired OSD language among English, French, Spanish, German, Italian, Portuguese, Polish and Dutch.
# Digital Data Transfer Function with IEEE1394
By incorporating the IEEE 1394 (i.LINK is a serial data transfer protocol and interconnectivity system, used to transmit DV data) high speed data transport port, both moving and still images can be transferred to a PC, making it possible to produce or edit various images.
# USB Interface for Digital Image Data Transfer
You can transfer images to a PC using the USB interface without an add-on card.
# Photo
The photo function lets you capture an object as a still along with sound, while in camera mode.
# 900x Digital Zoom/20x optical zoom
Allows you to magnify an image up to 900 times its original size.
# Color TFT LCD
A high-resolution color TFT LCD gives you clean, sharp images as well as the ability to review your recordings immediately.
# Digital Image Stabilizer (DIS)
The DIS compensates for any handshake, reducing unstable images particularly at high magnification.
# Various Digital Effects
The digital effects allows you to give your films a special look by adding various special effects.
# Back Light Compensation (BLC)
The BLC function compensates for the bright background behind a subject you're recording.
# Program AE
The program AE enables you to alter the shutter speed and aperture to suit the type of scene / action to be filmed.
# Digital Still Camera Function
* Using Memory card, you can easily record and playback standard still images.
* You can transfer standard still images on the Memory card to your PC using the USB interface.
# MPEG Recording
MPEG recording makes it possible to record video onto a memory card.
Come with: camcorder, original box, all paperwork, charger, two brand new minidv tapes, and a 128mb Sony memory stick.
Im looking for $225 shipped.
# Photo
# Color TFT LCD
# Program AE
# MPEG Recording
