Sold Sadly i have to :(:(
audiobahnuser18
Alright guy's as much as this kill's me to do:(//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif i have to sell off ALL of my audio equipment . turns out the 89 lincoln mark vii i have has a rear main seal oil leak and i can not fix it because have to pull ***** and engine out just to get to seal. so here it goes sadly:(. PLEASE NO LOW BALLERS need the cash bad guy's. Even though this kills me:(//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif:crying://content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif.
Will have pics up upon request i do not have paypal so you would have to send me Cash in an envelope to me or a money order will work also.
1.) DLS Ultimate A series Amplfier was going to test it to speakers but never got to but i know does power on and does not blow fuses or go into protect: $550
2.) Massive CK6 Comp set BNIB never even powered: $132
3.)Digital Audio Monoblock DAB1800x : $200
4.) IOSX 4awg wire around 18ft of it will measure though: $50 with fuse holder $55
5.) Sound storm 7band eq:$65
6.)Stinger Yellow Rcas: $20
7.) Tsunami 4awg: $35
8.)Tsunami battery terminals for 2 runs of 4awg and also 8 both of them :$24
9.)Pioneer Premier Rev's: $180
10.)Schoche cheap Rca's: $10
11.)Pioneer DVC 12" sub's: $80 each
Pics upon request. please no low ballers serious offers as this is me enough that i have to do //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif:(//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif.
Alright guy's i finally just got the chance and found a speaker my friend let me use to test to check speaker channels both work left and right and powers on and powers off once the remote wire is taken off like should. does not blow fuses or go into protect either.
So the DLS A3 amp works //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif. **** wish didn't have to get rid of her though:(
these are the 800watts rms pioneers right? theres so many diff models i cant tell the diff and the last guy linked me to some comps. not the subs that i was wondering about
lol yeah man . Here are the specs of em.
DVC
Size 12"
Woofer Cone Material Composite IMPP Cone using Interlaced Aramid Fiber
Woofer Cone Design Cone Reinforcement Arcs
Surround Wide Roll, Three-Layer Fiber Woven Radial
Voice Coil 4-Layer, Long Voice Coil
Voice Coil Wire Polyester-Imide Resin Coated
Voice Coil Bobbin 12 Slit Aluminum
Damper (Spider) Conex
Damper Ring Yes
Top Plate Standard
Projected Pole Yoke with Vented Pole
Magnet Construction Double Mass High-Power
Basket Design Stamped Basket with Magnet Cover
Gasket Molded
Wire Terminals Spring-Compression
Specifications
Watts MAX. Music Power 1000 Watts
Watts Nominal Power Handling 400 Watts
Frequency Response 18 ~ 500Hz
Sensitivity 89dB
Ohm Rating SVC:4, DVC: 2 or 8
Recommended Enclosure 0.85 ~ 1.75 Cubic Feet
Dimensions 13" x 7"
Mounting Depth 6-1/4"
audiobahnuser18
audiobahnuser18
Mi
audiobahnuser18
