Rockford Fosgate T600.4
DCbass
Rating: 66.7%
2 1 0
8.5/10 cosmetic, 10/10 Mechanical
Its closer to 10 cosmetically,
Specs 4-channel car amplifier
100 watts RMS x 4 at 4 ohms (150 watts RMS x 4 at 2 ohms)
300 watts RMS x 2 bridged output at 4 ohms (2-ohm stable in bridged mode)
CEA-2006 compliant
Dynamic Thermal Management cooling system
Differential Input circuitry eliminates hum
variable high- and low-pass filters (20-500 Hz, 24 dB/octave)
variable bass/treble boost (0-18 dB at 45 Hz, 0-12 dB at 12k Hz)
optional remote bass/treble boost
Class-AB amplifier design
MOSFET power and output stages
preamp inputs and outputs
4-gauge power and ground leads and a 150-amp fuse recommended — wiring and hardware not included with amplifier
no on-board fuses — when installing multiple amps in a system, an additional 150-amp in-line fuse between the distribution block and the amplifier is recommended
14-15/16"W x 2-1/4"H x 9-5/8"D
360 OBO!! OBO!!
Split shipping
DCbass
DCbass
Kinston, NC
DCbass
