Sold Rockford Fosgate T20001BD F/S
ThePunch
Rating: 50%
1 1 0
SOLD!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Up for grabs is a Rockford Fosgate T20001BD this amp means buisness. It is about 6 months old and was well taken care off. It comes with the Origonal box, birth sheet, bass knob and phone cable. Looking to get $350.00 shipped w/insurance. and I paid alot more for it, my loss is your gain there is nothing wrong with it. e. can e-mail me at skatingpmpn@aol.com
I will only do trades for in-dash screen that plays mp3's and sirius compaitable, Clarion , ALpine, Eclipse ,Kenwood
In the real world, an individual with too much power eventually becomes corrupt. In the car audio realm, you can enjoy the absolute power of a Rockford Fosgate T20001bd without becoming corrupt! The legendary name of Rockford Fosgate continues to impress the audio community and pump out subwoofers and amplifiers that exceed expectations. The T20001bd pushes out no less than 2000 watts continuous power. The birth sheets included with these amplifiers have been known to make hearts skip as the power ratings go beyond the rated value.
If you look under the hood of the T20001bd, the first thing you will notice is the custom TO-247 MOSFETS. These have 60% more metal tab area for more power capacity, lower impedance and improved heat dissipation over traditional TO-220 MOSFETs found in competitor amps. This Rockford amp is also a class bd design that has 75-80% efficiency ratings vs. 20-60% efficiency ratings of traditional class A/B amplifiers. To top it off this amp uses MEHSA (Maximum Efficiency Heat Sink Application) which is a proprietary process that yields better heat transfer than traditional FET mounting techniques. The MEHSA substrate is so efficient at reducing MOSFET temperatures, it lowers distortion, increases durability and results in a prolonged life span.
The Rockford Fosgate Power Elite Amplifier T20001bd is a workhorse that can pull more than its fair share. We recommend that you purchase another battery and a bigger alternator to truly grab the power this amplifier has to offer! This power hungry amplifier wants big subwoofers, so you better do what it says. You wouldn't want anything with this much POWER to be angry, would you?
* 2000 Watt RMS Class BD Amplifier
* RMS Power Ratings:
o 750 watts RMS x 1 at 4 ohms
o 1,500 watts RMS x 1 at 2 ohms
o 2,000 watts RMS x 1 at 1 ohm
* Para-Punch bass EQ (0-18 dB with variable center frequency between 35-70 Hz) with wired remote control
* MEHSA- High Performance Thermal management design for bigger power with more consistent thermal stabiity
* MOSFET power supplies and outputs
* TOPAZ - Circuit for eliminating engine noise
* NOMAD - Advanced short circuti and power protection
* MasterSync - allows one amplifier to manipulate another amplifier's gain, EQ, Infrasonic and crossover controls
* PowerSync - Allows bd series amplifiers to be "strapped" together to create one massive power combination
* variable low-pass filter (32-250 Hz, 24 dB/octave)
* Infrasonic filter: 12dB/oct Butterworth alignment protects the amp from unwanted ulta-low frequency information, increasing the usable power output and reliability
* RCA Preamp Outputs
* Phase switch: 0 - 180 degrees
* Cast aluminium heatsinks - allows more power into a smaller heatsink by allowing engineers to localize heat in specific areas
* 3-Stage Variable forced convection - heatsink design that keeps the amp's internal components cool
* 1/0 AWG power and ground connections with internal ANL fusing
* Dimensions: 23" L x 12.8" W x 2.66" H
Hopes everything gets resolved bro. I would've been a little weary cause the price screams scam. Like the saying goes if it sounds to good to be true it proly is.
starting to look that way with no contact and # as promised.this is making it hard for me to trust anyone else.
ThePunch
ThePunch
Michigan
1lowZ56tahoe
