rockford fosgate p5002 wire size ?
big scott
blazin low, and loud
hi guys,
i have an older rockford fosgate p5002 its a 2channel amp.
ratings
500rms x 1 at 4 ohms ( Bridged (Mono) )
250rms x 2 at 2 ohms
125rms x 2 at 4 ohms
i downloaded the manual but now were does it recomends a power/ground wire size.
so knowing the specs what size wire should i use ?
im going to install 1/0 " big 3 " and distribution blocks.
so i need to pick a block with that size output.
thanks guys.
ok thanks guys.
but 1 more ?
ill be running that amp plus a 2 channel amp (75rmsx2 ) thats for my r.f. 6x9"
and i plan on getting a 2-channel amp (40rmsx2 ) for a set of pioneer 4x6 in my dash.
that all i plan to run right now.
so would the 4ga. be ok for this ? or should i get a 1/0
as i would run 1/0 to a block with 1 input x 3 outputs ( output 4ga to 8ga on all 3 )
big scott
big scott
edgewood, md
big scott
