Rockford Fosgate P500-1BD
9/10 cosmetically and 10/10 functionally. Works Like an absolute champ and underrated. From what I gather it does more like 700 rms into 1 ohm. Rockford Fosgate recommends a 100 amp fuse for this little guy(not a misprint,I checked myself many times LOL) Great small foot print amp for a single sub and in awesome shape.
Full Specs copied and pasted from sonic electronix:
Punch Series Monoblock Class BD Car Amplifier
RMS Power Rating:
4 ohms: 200 watts x 1 chan.
2 ohms: 400 watts x 1 chan.
1 ohm: 500 watts x 1 chan.
MOSFET power supply
Remote bass level input (remote level control sold separately)
LED power, thermal, and protect indicators
Tuned Bass EQ (0-18 dB bass boost at 45 Hz or 0-12 dB bass boost at 12 kHz depending on crossover selection)
On-board differential inputs eliminates noise picked up by the signal cable
Mono channel operation
RCA Pass-thru outputs
Featured custom designed TO-247 MOSFETs have 60% more metal tab area providing more power handling capacity, lower impedance and improved heat dissipation over traditional TO-220 MOSFETs found in most competitor's amps.
Built-in NOMAD is a "real time" analog computer that protects your amplifier from shorting speaker wires and dangerously low speaker impedance.
MEHSA3 reduces MOSFET temperatures, lowers distortion, and increases durability
Cast aluminum heatsink evenly distributes excess heat across entire amplifier heatsink
Nickel-plated RCA level inputs
Nickel-plated screw terminals
Variable low-pass filter (35-250 Hz, 12 dB/octave)
Selectable infrasonic filter (28 Hz, 12dB/octave)
CEA-2006 compliant amplifier
Frequency response: 20-250 Hz
Dimensions: 10-1/4"L x 7-5/8"W x 2-1/4"H
Power Specifications - Subwoofer Channel
RMS Power @ 4 ohms 200 watts x 1 channels
RMS Power @ 2 ohms 400 watts x 1 channels
RMS Power @ 1 ohm 500 watts x 1 channels
Amplifier Specifications
Amplifier Class BD
Number of Channels 1 - Mono
Total RMS Power Output 500 watts
Maximum Input Gauge Size 4 AWG
Minimum Impedance Unbridged 1 ohms
Minimum Impedance Bridged Not Bridgeable
THD at Rated RMS Power 1%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover Low-pass (LP)
Low-Pass Crossover Frequency 35 - 250 Hz
Signal-to-Noise Ratio 100 dB
Bass Boost 0 - 18 dB
Bass/Gain Remote Optional (Accessory required and sold separately)
Rockford Fosgate PEQ
Fan Cooled No
Fuse Rating 100A x 1
CEA-2006 Compliant Yes
Asking 150 Shipped in the US
Shipping Included in Price
RMS Power Rating:
MOSFET power supply
Amplifier Class BD
Fan Cooled No
