Sold Rockford Fosgate P2's 8ohm SVC 10"
Tacosys
I have 2 Rockford Fosgate P2's, 8 ohm, single voice coil, 10" woofers that I am selling for a friend. Subs are in a 9/10 cosmetic and a 10/10 mechanical. You can wire them down to a 4ohm load. I believe they are 200RMS and 400 peak. I would like to get $80 shipped for the pair. And yes I know you can get these for around $50 new, but after shipping it more like $70. These subs aren't even broken in yet. Specs:
Size 10"
Impedance 8-Ohm
Power Handling 200 RMS 400 Peak
Sensitivity 86 dB
Motor Size 60 oz. double stacked
Voice Coil Diameter 2"
aluminum Speaker Connector
Dual 8 AWG compression
Mounting Depth 5.6875"
Rec. Sealed Enclosure 0.65 cu. ft. 18.4 liters
Rec. Vented Enclosure 1.25 cu. ft. 35.4 liters Tuning Frequency (vented) 40 Hz
Shipping Weight 11.75 Lbs.(5.3 Kg.)
Tacosys
Tacosys
Cincinnati
skylineTT
