Sold Rockford Fosgate 800.4 going CHEAP!!
RetroAudioinc
Custom Car Audio Decals
1. Product:
2. Specs:
The MOSFET power supplies in Rockford Fosgate's Punch 800.4 four-channel amplifier send power screaming to all the speakers in your system! At the same time, the combination of proprietary technology and clean circuit design give you a sparkling, detailed performance.
Built-in high-pass/low-pass crossovers let you tweak your tunes to work with your vehicle's natural acoustics. Punch Bass provides up to an awesome 18 dB of boost at 45 Hz for all the low-frequency slam you'd ever want.
* 200W RMS x 4 at 2 ohms
* 400W RMS x 2 in bridged mode
* 2-, 3-, 4-channel or Tri-Way output
* Front and rear high-pass/low-pass crossovers (variable 50-210 Hz, 12 dB/octave)
* MOSFET power supply and output devices
* Maximum Efficiency Heat Sink Application (MEHSA) mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
* TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
* *****•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
* NOMAD — advanced protection circuitry for "intelligent" shutdown protection
* Speaker-level inputs
* preamp outputs
* Punch Bass boosts bass up to 18 dB at 45 Hz
* 4-2 switch
* 60-amp fuse and fuse holder required
* Dimensions: 18-7/16"W (14-7/8" without endcaps) x 2-7/16"H x 9-7/8"D
3. Description/Condition:
Used
Tested and works 100% when tested.
I would rate it 8.5/10 it's in good shape for it's age.
4. Price: :
Lets start at $300 OBO
5. Pictures: Old photos but still in same shape just sitting in my storage unit. Nice unit..
Someone asked if I had both end caps, not sure why since there both in the photos and yes I have them both are on the amp.
Lets have a huge price drop how about $180 picked up or $195 shipped in lower 48 states..
RetroAudioinc
RetroAudioinc
Indianapolis, IN
RetroAudioinc
