Sold Rockford Fosgate 325.1 sub amp
SQStephen
SQL
Rated Power: 175W x 1 @ 4-Ohms RMS
continuous power: 325W x 1 @ 2-Ohms RMS
Total Power: 325 Watts
4 Gauge power/ground connections with built-in ATC fusing
Aux Ouputs
Connector Cover
Focused mass heatsink design
Stealth Connections
Thermal Sensing
Top Mounted LED Indicators
Crossover Controls: High-Pass (HP): 40-400Hz 12dB/octave Butterworth
Low-Pass (LP): 40-400Hz 12dB/octave Butterworth
Tone Controls Bass: 0dB to +18dB @ 45Hz
Signal Input Low level: 1 RCA pair
Signal Output Low level: 1 RCA pair
Block Power Input Connector
4 AWG Power Wire Gauge
$130.00 SHIPPED TO YOUR DOOR.
Screw terminal barrier strip Speaker Output Connector
8 AWG to 18 AWG Speaker Wire Gauge
Cast aluminum Heat Sink
Convection Cooling
Punch Bass EQ (included with cable) Remote Controls
Visual Indicators: Power On, Signal Level, Thermal Status, Speaker protection
Class-bd Circuit Topology
Frequency Response: 20Hz to 20kHz +/- 0.5 dB
Dimensions (HxWxL): 2.1 x 11 x 11.7 (in), 5.3 x 27.9 x 29.7 (cm)
SQStephen
SQL
SQStephen
Canada
SQStephen
