I have this amp that I dont need anymore, and Id rather have the money than have it sitting around.
The amp is a Rockford Fosgate PUNCH series 301S. A few specs on it:
75x2 at 4 ohm
150x2 at 2 ohm
300x1 at 4 ohm, bridged.
Frequency Response 20 Hz - 20000 Hz
Signal to Noise Ratio 100 dB
THD at Rated RMS Power 0.05 %
Bass Boost Frequency 45 Hz
Low - Pass Frequency 50 Hz - 250 Hz
High - Pass Frequency 50 Hz - 250 Hz
Comes with a remote bass boost. The face plate on the knob is a little scared up, and the insulation on the outer wire is worn through, but not into the actual wires inside.
Amp is in fairly good shape cosmetically. A few little scratches, and on the side there are some rub marks from my seat. When the end caps are on you really dont notice much though.
The gain nobs are a little messed up too. They are plastic and set back in the amps chasiss, and the tool I used to set them marred them up some, so they can be a PITA to turn, but they work fine.
Here are some pics, if you would like more just let me know.
I also have the plug that you use for speaker level inputs, and the manual for it.
If you need any wiring for it, talk to me also //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I could put together a whole amp kit for it if you want for a little extra.
Looking for $85 plus shipping. Money order or cashiers check only please //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thanks for looking.
75x2 at 4 ohm
150x2 at 2 ohm
Thanks for looking.
