Sold Rockford Fosgate 1501bd Power Amp - Birthsheet = 1668w RMS @ 2ohm
AllStar1500bd
Times have changed
I'm selling my 1501bd. I was the original owner on it - purchased it in late 2003 brand new. I have the original box. This was installed in my 96 Explorer since 2003 and powered a set of Power HX2 15"s.
I have NEVER pushed the gain high at all - I didn't need to since it's 1668 wRMS @ 2ohm.
Functionally, it is 100%. Cosmetically, there are some scrapes and marks on it from being installed in the back of my Explorer for 4 years. One of the sides of the endcaps has its screw missing (easy fix). Nothing is stripped on any of the inputs. Check the pics...
Dollar bill not included, just so you can see it's size //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Price dropped to $350. This is below what other 1501bd's went for on eBay, and those didn't have their original box or birthsheet.
Here's one with LESS RMS, and it went for $450 shipped = http://cgi.ebay.com/Rockford-Fosgate-Power-1501BD-Car-Audio-Amplifier_W0QQitemZ180224205700QQihZ008QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Here's some factory specs...
Code:
[list]
[*]750 watts RMS x 1 at 4 ohms
[*]1500 watts RMS x 1 at 2 ohms
[*]Class bd technology
[*]selectable 50-250 Hz variable low-pass crossover, 24 dB/octave
[*]MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
[*]TOPAZ noise-killing differential inputs eliminate 80% of ground loop noise
[*]preamp outputs for easy connection to a second amplifier
[*]wired remote control of Punch Bass (0-18 dB centered at 45 Hz) — gives you fingertip control of your bass impact
[*]subsonic filter removes frequencies below the range of human hearing for increased efficiency
[*]bd Sync — allows two identical Class bd amps to be tied together to power one woofer (using an optional cable)
[*]17-1/8"W x 2-3/8"H x 9-7/8"D[/list]
AllStar1500bd
Times have changed
AllStar1500bd
Oregon
AllStar1500bd
