Sold rockford fosgate 1000.1 bd
subdicted
OK i would like to trade out this amp for something of similar power handling.
I posted a thread before asking what could be wrong with this amp, most ppl said the subs were wired up wrong. For some reason it just pops fuses, don't even get powered up or play any music at all.
Idk how to fix it, but maybe its an easy fix. so im just looking to trade it with less value but still around 1000rms power able. this is under rated an was putting out around 1600 rms at 1 ohm.
if you guys have anything to trade let me know. i don't want any subs though.. need an amp. thanks
I posted a thread before asking what could be wrong with this amp, most ppl said the subs were wired up wrong. For some reason it just pops fuses, don't even get powered up or play any music at all......this is under rated an was putting out around 1600 rms at 1 ohm.
last I knew a bd1000 was 2 ohm stable, and you refer to it running ~1600w @ 1 ohm, if you are popping fuses I am curious if this was the problem and the low ohm load just blew the amp up?
subdicted
subdicted
kuna, ID
subdicted
