Rim specialist please help!
bassknocker23
OK, So Raben, wheel city will not put 22's on my buick. They say it won't work and they dont do lifts. So what can I do? would I need that much of a dramatic lift on my car to fit 22's on it;? because I know i will regret it if i put 20's on there
22's on Buick LeSabres are all day around me Just get the right offset and the right size tire....Might rub a little but nothing a little cutting cant fix...
20'S ARE PLAYED OUT!
I just bought a set of 22's for my 79 Cutlass off ebay with rubberband tires , New shipped to my door for a little over $1200....
Check out eBAY you can get the right wheels and the right size tires for CHEAP!
If it's the big body buick then you will need a 22" wheel that's no wider than 8-8.5 inches with an off-set of about +35 to +45 and use a 235/30/22 tire. You may still have some rubbing on a lockout turn though.....//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif:D:D
^exactly what he said....they said 22's wouldnt fit on my grand prix either but you can fit them with no problems if you go 22x8.5 with a high offset and 235/30/22 tires.
My bro just put all black 22's on his 06 Grand Prix GT.......Had no problems at all
U dudes sure about HIGH offset?? I would do 22x8 wit 235/30/22 tires.. you can put Spring spacers in.. get about 2 inches of lift that way.. and it cheap do it yourself all u need is a floor jack..
my dude had 22x8.5 on his 95 monte on 255/30 tires.. offset was 20 and it didnt rub at all.. his new ones were 22x8.5 wit same dimension tires but offset was 35 and rubbed his strut plates in back and fender well in front.. 1 and 1/2 inch adapters later he is rollin clean again, but pokin out an inch more
bassknocker23
bassknocker23
Indiana
bassknocker23
