Southeast Region Richmond, VA - 08/26/2012 Likuid Glass Kustomz & Team Deadly Hertz Bass Off
AR,AL,GA,FL,KY,LA,MS,NC,SC,TN,VA
I knew the amp had been to a shop at some point and I always wondered if it was modded, memphis said un-modded would go protect so it hasn't and it's only getting warm running it hard and the voltage isn't nearly as bad as I expected but I could use a second small battery but the lowest I have seen is 11.9!
CAT MAN is bringing his clamp and meters and shit......We need to see what this beast does @1ohm
clamped mine earlier before my dmm almost killed me
35 hz 12.4v 67.9(dmm) and 29.4(clamp)
40hz 12.6v 72.1 and 23.1
your going to have to break that down for me, I've never done more then set my gain with a dmm.
at 35 hz and 12.4v it did 1996.26 at 2.3 ohms
40 hz at 12.6v it did 1665.51 at 3.1 ohm..
gains set for trunk 0-1800 class but after the second batt the numbers went up
at 35 hz and 12.4v it did 1996.26 at 2.3 ohms 40 hz at 12.6v it did 1665.51 at 3.1 ohm..
I need to come up with some cash for an extra battery, I don't like the fact I can drop into the 11's and I really don't want to kill this amp.
Thanks for the link to this video, I've seen this one before but it's not for component speakers which is what I'm going to install and the part...
840
Try crutchfield.com and use the application that gives you replacement options for system components. I ripped out the entire system in my Mustang...
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
Nice, much better looking version Ford than its American counterpart. Go down to the local stereo shop and tell them you want to the work yourself...
JayDubb757
JayDubb757
Hampton, VA
JayDubb757
