Sold RF Power 1500bd - 2002 model with grey case (1823 RMS at 2 ohm, is also 1 ohm stable)
s_carter
¡¡¡ɹǝʌo ǝɯ lloɹ
Rockford Fosgate Power Series 1500bd. Rated 750 watts RMS @ 4 ohm, and 1500 watts RMS @2 ohm. Original owner said birth sheet was 1823 RMS @ 2 ohm, and that this amp is also 1 ohm stable.
Good working condition, no bass remote or endcaps. No major defects on the cover, some slight spots on back cover. All knobs and switches work as they should. There is some slight torroidal vibration when its cold sometimes, but clears up within a few minutes of turning on. Does not affect the functionality of the amp, but it seems to be a fairly common issue among these amps....
Class bd technology
750 watts RMS x 1 at 4 ohms
1500 watts RMS x 1 at 2 ohms
requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
4-gauge power and ground connectors
150-amp fuse and fuse holder required
selectable 50-250 Hz variable low-pass crossover, 24 dB/octave
MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability.
TOPAZ noise-killing differential inputs eliminate 80% of ground loop noise between the head unit and the amp.
NOMAD advanced protection circuitry monitors temperature, voltage, current and impedance, and provides "intelligent" shut-down protection without limiting system performance.
preamp outputs for easy connection to a second amplifier
wired remote control of Punch Bass (0-18 dB centered at 45 Hz) — gives you fingertip control of your bass impact
POWERsync — a 6-pin mini-DIN connector that allows you to bridge together two separate Rockford Fosgate Class bd amps
subsonic filter removes frequencies below the range of human hearing for increased efficiency
dimensions: 18-1/2"W (13-11/16" without endcaps) x 2-7/16"H x 9-7/8"D
$300 + shipping. I will take a partial trade, I am looking for some 18" to 21" baskets, and various softparts for a franken sub project with ge_off_me. Maybe we could work something out?
I am really looking for a Rubicon 800.5, if you got one, I will trade for it.
Shipped from 97203.
Well, I can guarantee this amp's thermal, short, and over current protection circuit has not been modified, removed, or bypassed in any way. I have personally inspected and tested it, and it works just as it should.
$250 shipped! Come and get some uber RF bumpage!
s_carter
¡¡¡ɹǝʌo ǝɯ lloɹ
s_carter
Portland, OR
Ge_off_me
