I never wanted to part with this amp but times have gotten tough, so here it is.
Specs/info:
Definitely the most famous amplifier Rockford Fosgate ever manufactured, the Power1000 includes all the stuff legends are made of. The '25 to LIFE' special edition amp takes the classic Fosgate powerhouse style into today's design with a staggered power five-channel configuration. Put one of these in your car and you'll be set to knock everyone's socks off.
20Hz to 20kHz +/- 0.5 dB Sub Channel 20Hz to 250Hz +/- 3dB
1400W Total RMS Power, '25 to LIFE' Special Edition Staggered 5-Channel Amplifier
Class bd Subwoofer Channel/Class AB Main Channels
RMS Power Output:
4 ohms: 50W x 4 channels plus 300W x 1 sub channel
2 ohms: 100W x 4 channels plus 600W x 1 sub channel
1 ohm: 150W x 4 channels plus 800W x 1 sub channel
Bridged rating for front/rear channels:
4 ohms: 200 watts x 2 channels
2 ohms: 300 watts x 2 channels
Built-in Variable Crossovers:
Front/Rear Channels 1-4: Variable 40-400Hz, 12 or 24db/octave Linkwitz-Riley High- and Low-Pass Crossovers
Sub Channel 5: Variable 32-250Hz, 24dB/octave Linkwitz-Riley Low-Pass Crossover. Also has a subsonic (infrasonic) filter at 28Hz fixed.
Crossovers all use 24 dB/Octave Linkwitz-Reilly Crossover Alignment
Frequency Response:
Front/Rear Channels 1-4: 20Hz to 20kHz +/- 0.5 dB
Sub Channel 5: 20Hz to 250Hz +/- 3dB
Bass Boost: 0dB to +18dB @ 35-75Hz (sub channel 5 only)
1 Ohm Stereo/2 Ohms Mono Stable
Wired Remote Para-Punch Bass Control
Removable Connections Shroud
5-channel Level Monitors
Chrome Shroud Cover
Power Meters
Indicator Lights
1/0 Gauge power/ground connectors
Built-In ANL Fusing
Cast aluminum heatsink
RCA pass-thru
Stealth Connections
*****-ana (TRANSconductance Active Nodal Amplifier) design simplifies the input circuit path for transparent and uncolored sonic performance.
MEHSA (Maximum Efficiency HeatSink Application) yields up to 5 times better heat transfer from the Mosfet devices to the heatsink.
Focused Mass heatsink for increased efficiency and reduced distortion.
3-Stage Variable Forced Convection cooling for superior heat dissipation and maximum protection.
Custom designed TO-247 output Mosfets have 60% more metal tab area for improved thermal stability and wider linearity.
Military Specification (Mil Spec) Glass Epoxy circuit boards accept larger copper traces for better current flow and resist vibration much better than inferior fiberglass circuit boards.
Dimensions: 23"L x 12-3/4"W x 2-5/8"H
Actual power output is way higher than rated, I'll try to add actual birthsheet numbers later when I have it in front of me.
I am the original owner of this amp and it is in great working condition. I have original box, manual, birthsheet, etc that will be included. This is my first transaction on CA but plenty of ebay feedback (username; dlehneman). Amp will be double boxed and insured.
$400 shipped and insured.
Specs/info:
RMS Power Output:
Frequency Response:
Chrome Shroud Cover
Power Meters
Indicator Lights
Built-In ANL Fusing
RCA pass-thru
Stealth Connections
