respectable spl score?
anyone who hits 85 or higher in any situation has an unbeleivable system
//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
wtf are you talking about. isn't like the db for just average conversation like 80 db's?
//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gifwtf are you talking about. isn't like the db for just average conversation like 80 db's?
Something like that. In most cases you need to do at leaset 100dB for it to regester on the mic.
OK...
Pioneer head unit
6 infinity kappa 6x9's
4 Linear compression audiobahns 12", 2000 rms each
4 2 ohm mono audiobahn sub amps model not sure
4 scosche digital capacitors
dual optima deep cycle batteries
140 amp alternator
scosche wires
4 2.00 sealed or ported boxes 1" Fiberboard
you sir are a retard, 140 amp alternater is not enought to supply that much power.
"sealed or ported boxes" which one is it?? wat mic was used?wat are u doin wit 6 6x9's?wat car? it just seems a little fishy to me.
you sir are a retard, 140 amp alternater is not enought to supply that much power."sealed or ported boxes" which one is it?? wat mic was used?wat are u doin wit 6 6x9's?wat car? it just seems a little fishy to me.
It's about as fishy as a seafood place down on main street //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
- Steve
um how are you running 4 subs rated at 2000 watts each with a 140 amp alt? even if you only gave them 1000 watts each thats 285 amps even with a 14 volt battery. 320 amps if you have a 12.5 volt. (assuming the amps arre 100% effecient)
by the way guys i was just messing with you on the 85 dB thing lol.
yes to audiobahn SPL i raise a rather large BS flag mighty high in the air unless you show proof. i'm sorry but on any meter you use at any comp. with that score you would have a State record and possibly go to world finals for your class. now not to mention that if you can manage to pull upper 150's to 160's with 4 12"s and 8kw of power with only 8cuft total airspace then you have literally the most amazing install words could describe. SPL= airspace, power, electrics, and knowledge. you seem to lack many of the above.
adam
bone10001
bone10001
uk
havoc06
vegang
vegang
