Resistor power ratings for PPI amp
kcr357
anyone have an idea of what these need to be?
Would 1 watt be enough? Haven't been able to find a schematic to look up the exact specs...
It's a surface mount from a ppi bk520.4
anyone have an idea of what these need to be?Would 1 watt be enough? Haven't been able to find a schematic to look up the exact specs...
Did you buy that table from Edward Scissorhands?
Where is the resistor in the circuit? That will determine an appropriate power rating. If it is in the input section than 1/8W is plenty. If it is in the power supply section than it may be more. Power ratings will affect size so measure with a micrometer and compare with Digikey, Mouser, etc.
I do upholstery, it's my cutting
The fuse is right at the outputs, there looks to be one f9r each channel
kcr357
kcr357
ft laud
kcr357
