LosIsATool
Try a set of the 28mm Hertz tweeter and run a clean 75 watts to them. You will have your super tweeter that can also drop down to the 2400hz range.
Super tweets pick up the very high freq and play them very loudwhats the diff between super tweets and regular tweets?
Since no one else is even noticing your posts I will.. These are the best listed the 350s that isSelenium ST350 Super Tweeter 264-362
U can thank me later.. Ran a pair on bout 60watts each crossed at 4k and son they were loud and crisp..
Lil less quality "but much better then ur avg jow blow super" but alot less then the 350's.
Selenium ST200 Super Tweeter 264-348
Nope the correct and only real one is the st350's. The rest are mehh at best... Spend ur money wisely and you will forever be happy. The 350 will just destroy anything else listed in this thread in output and sq. End of thread. Creo and DD supers are just cheap bullets with a badge slapped on the case....so many dam* choices! XD
this..Nope the correct and only real one is the st350's. The rest are mehh at best... Spend ur money wisely and you will forever be happy. The 350 will just destroy anything else listed in this thread in output and sq. End of thread. Creo and DD supers are just cheap bullets with a badge slapped on the case....
