reccomend a 10
bird_dog0347
DFW
I have a 12.5x12.5x12.5 3/4 mdf sealed box, and the amp I will be using is a PPI DCX800.5.
The sub channel is 400 x 1 @ 2 ohms (12.5v), and the sub I currently have is a SVC 4 ohm Infinity perfect 10.1. If I use it, i will only get 200 x 1 @ 4ohm. I have the same amp in my boat pushing a 10w6v2 and it sounds great, but the box is totally different. I really would like to get something that hits pretty good, with great SQ and not spend that much. What are the best options that will work with what I have and give me a 2ohm load from a single 10?
As for budget, not sure... less than 200 would be best, closer to 100 if possible, willing to buy used.
I don't have the fusions installed yet. I started to install them last Saturday but I was not feeling great and the wife got called into work so I had to watch my 4 month old all day. I will try to get them installed this weekend.
That is a SVC 8ohm sub... I need a single 10 in sub that is either SVC 2ohm or DVC 4ohm.
Also, I was looking at some of the subs recommended, but they are like 250W RMS... this amp will put over 400RMS at 2ohms, will that be a problem for the subs listed so far?
I think you should sell that amp if possible and get buy a new or old amp that spits out 1500 watts and a sub to match it. Your only going to want to go louder once you get what your asking for.
Not really... I could care less about loud, as long as it sounds great at the volume I like to listen to. I already know what it is capable of with the system in my boat, which is far more than I would ever want in my truck. If it is not how I want it, I will simply get a 10w6v2 and a good box for it and call it a day. I want my truck to sound as good as my boat, but I really did not want to shell out that much for a sub...
bird_dog0347
bird_dog0347
DFW
Mitch86
vegang
vegang
