Rebuilt Eclispe sw9122's. need tuning insite.
sleazebagger
nobody!!!
Bought these off of here from wingman0121 and need a box built.
I have a builded and ram design to do the cad. I just need some input as to what to tune these to.
I will be running 2 x zapco 1100.1's.
800 rms @ 4 ohms to each sub.
Obviously not trying to get real loud. I'd like to get a lot of kick out of these and from my limited knowledge I'm thinking a higher tuning of like 34 hz with subs facing hatch/side by side and areo ports in the bottom corners.
This is going into a 2003 sploder xlt.
I think it will get alot louder then you may think assuming the correct box is used.. I say subs up port back. 34hz sounds good to me. My box is tuned to 33hz and I can play all the way down in the 20's and all they way up to the high 40's with authority..
My last setup was like that and it was very boomy. Although I think the tuning was around 30hz at 2 ohms.
The big reason I want them facing the hatch is so I can lay my painting gear in the back and I dont want latter's resting on my subs.
sleazebagger
nobody!!!
sleazebagger
Madison, WI
sleazebagger
