they are around $400 shipped from RE. That would underpower them a little but it might work. I would look into the HIFONIS 1500D. A lot of people on here run this setup so just ask around and they can tell you how good it is..
Now that I think about it I believe the XXX is a Dual 4 ohm so you could only get 1000w RMS out of either amp. My bad I wasn't think when I put down the HIFONIS. I don't know if there are any 2 ohm XXX so either one of the amps would work.
That amp will do an excellent job. Just gotta build a good box //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The XXX is dual 2 ohm, so it needs to be run at 1 or 4 ohms, so you're amp would not work very well with it, if you are on a budget the Hifonics would be a good choice.
so neither a XXX or a D2 can be wired to 2 ohms??? that *****. I just got this PG Tantrum that is 1507 x 1 @ 2ohms. I was planning on running it to a XXX. It is only 1200 @ 4 ohms.
