re xxx
usa 1
i have a 15" xxx in a 6 cuf. ported box tuned to 36 hz. its hooked to a audiobahn a1500hcq amp running at 1.7 ohms. could i possibly hook 1 more of those amps to it, and run them both at 1.7 ohms without blowing the sub.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif :confused:
Originally posted by usa 1 i have a 15" xxx in a 6 cuf. ported box tuned to 36 hz. its hooked to a audiobahn a1500hcq amp running at 1.7 ohms. could i possibly hook 1 more of those amps to it, and run them both at 1.7 ohms without blowing the sub.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif :confused:
I'm sure it'd take it for burps, but not for daily use.
The other question is whether your electrical system will hold two of those amps....if it's stock, chances are it's already struggling to provide your current amp with the power it needs to reach rated RMS power (i think that amp needs like 130amps of current to push full power).
Finally, if you put that much power to it, kiss your warantee goodbye. They rate it at 1600w RMS for a reason.
you wouldn't be able to run each amp at 1.17 ohms!! Your saying run 1 amp to 2 of the coils and same thing with the other amp right? Your choices would be to run each amp at .59 ohms or 2.34
I would throw the junky audiobahn away and get a 1200.1 or something like that
aho yeah, nick(usa1) doesnt get on hardely ever, but he has 2 alternators, and 2 batteries, he can support some bad *** power.
D
Originally posted by RMKrider1 you wouldn't be able to run each amp at 1.17 ohms!! Your saying run 1 amp to 2 of the coils and same thing with the other amp right? Your choices would be to run each amp at .59 ohms or 2.34
.3, 1.17, or 4.68
and that xxx will take that for daily if it was on 1 amp.
my electrical system will handle 2 of those amps. im running twin 140 amp alternators and twin deep cycle rv batteries. ok if the sub wont handle 2 of those amps then will the amp last if i run it at .3 to get more power. i had it meetered the other day and it hit 151.6 db's.
Nick, Nick, my 1-12 kicked your ***. but who metered you, was it boomers, yeah i remember the last comp they did off their shitty mic, when youi hit 143, yeah that van hit like 172.7, i can remember, and that guy got his *** kicked in the finals, he hit like 156 on a lin x..
D
Originally posted by fyrspray what is a xxx and who makes it? how much do they normally cost?
Respl.com You can check them out there //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif I've got a 10 thats still brand new in the shipping crate I'd let go for 280 plus shipping
Originally posted by RMKrider1 Respl.com You can check them out there //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif I've got a 10 thats still brand new in the shipping crate I'd let go for 280 plus shipping
oooooooooooh those are pretty XD
You what? Theyre goin for like 350 on their site i think... ****! i cant make up my mind xxx or ID MAX 12 im more of an SQ person
usa 1
usa 1
idaho falls id
fyrspray
