Sold re,treo,rf,pg,id
n00b
RFt10001bd.. 250 shipped SOLD
PG tantrum 500.2 100 shippedSOLD
treo 12: ssi 175 shipped
id horn set with 6.5"s (cd1e v.2) 250 shipped
re audio 8's (6 of em) 40 each shipped2 SOLD
audio control eqs 150 shipped SOLD
also have a viper 791xv alarm BNIB 150 shipped SOLD
RE SERIES
T/S Parameters
8”
Electrical Q Value -Qes: 0.38
Mechanical Q Value -Qms: 4.21
Total Speaker Q Value -Qts: 0.34
Free Air Resonance -Fs: 22.8 Hz
Equivalent Compliance -Vas: 27.1 liters
One-Way, Linear Excursion -Xmax: 12 mm
Efficiency -SPL 1W/1m: 81.2 dB SPL
Effective Piston Area -Sd: 195 cm^2
DC Resistance -Re: 3.2 ohm
Nominal Impedance -Znom: Dual 4 ohm
Thermal Power Handling -Pe: 175 W
Force Factor -Bl: 15.4
RE SERIES
Product Dimension
8”
Mounting Depth - 4”
Mounting Hole Diameter - 7.125”
Overall Diameter - 8.25”
Bolt Hole Circle - 7.75”
Motor Width - 4.875”
Motor Depth - 1.5”
Basket Depth - 2.5”
Displacement - 0.07 cu. ft.
Weight - 6 lbs.
RE SERIEST/S Parameters
8”
RE SERIES
Product Dimension
8”
Mounting Depth - 4”
Motor Depth - 1.5”
Basket Depth - 2.5”
Weight - 6 lbs.
****, me likey, but I can't do D4. Let me look into my amp situation. I'll let you know. Thanks for the quick reply.
- Mike
8”
RE SERIES
Product Dimension
8”
Mounting Depth - 4”
Motor Depth - 1.5”
Basket Depth - 2.5”
Weight - 6 lbs.
thx for postin that 4 me while i was away..
i assume u got the plug for the AC?
****, me likey, but I can't do D4. Let me look into my amp situation. I'll let you know. Thanks for the quick reply.- Mike
just lmk... u could wire 1 and get a 8 or 2 ohm load, 2 and get a 4 or 1 ohm, 3 and get 2.67 or .67 load, 4 and get a 2 or .5 load, 5 and get a 1.6 or .4 load or 6 and get a 1.3 or .33 load
so u do have some choices there...
what kind of amp do u plan on running?
n00b
n00b
dallas,tx
MSimz
